Hi, I´ve been using DJAY Pro 5 with MacOS for two months now, moving from Serato. I have a few improvement suggestions that I hope are helpful:
NEURAL MIX KNOBS/EQ KNOBS
- When the user changes Neural Mix and EQs for the mixer knobs, the controls are reset (as clearly stated in the legacy DJAY Pro AI manual). I just think that doesn’t make sense musically. Very often, I adjust the EQs of a track before playing or right after playing to make it sound good, but then, when, when I want to manipulate the its stems, the EQs adjustment is gone and the track sounds bad again! I´m using a secondary controler that allows me to control EQs in my main controler and stems in my secondary one, avoiding this incovenience, but really, I don´t a reason why one shouldn´t be able to switch between EQs and Neural Mix in a single controller or directly in the software without reseting the corresponding adjustments. I hope Algoriddim can reexamine that.
NEURAL MIX INSTANT FX
- Ok, I moved to DJAY from Serato, so I tried to reproduce in my pads the stems instant effects you have in Serato. Well, the “voice echo out” in DJAY Pro sound really good, better than Serato, I would say. But I really miss having “instrumentals out” instant FX options. I would suggest a nice sounding “instrumentals vinyl break” and classic “instrumentals reverb” or “echo out” options.
SLIP MODE
- I think a slip mode button should be visibile in all different view modes.
SAMPLER/LOOPER/SEQUENCER
- Well, I think the sampler/looper/sequencer have a lot of potential, but it lacks some basic features that really make them way less useful than they could be:
a) a button for cueing with headphones in all three modes;
b) a gain knob in all three modes;
b) the possibility of looping quantized samples in the sampler mode.
Sorry if any of these improvements is already available and I didn´t notice it.
Best regards
