Hello, thé next version of djay pro Windows will be 64 bits ?
Hi Dela,
djay Pro for Windows is running in 32 bits.
Are you experiencing any issues at your end?
Sorry for the misunderstanding.
djay Pro is running in 32 bits at the moment.
Are you experiencing any issues?
My djay pro is 32bit from Windows store, where Can i download 64bit version
Lucas, on this picture i see 32 bits, it’s normal ?
