Im using djay pro ai on a macbook pro and the lag is debilitating and overwhelming. It seems the program has taken a turn for the worse…its just not operating as well as it did a couple of years ago. The application is no longer user friendly and there’s no means to reach support VERBALLY. Please make this program great AGAIN!
Hey Todd, did you get this?
Your question:
If you could answer this it will be a great help, if you could make a video as well that will help to identify the issue. I upload my videos to you tube first then use link to put here as direct video uploads don’t seem to work. Of use drop box etc.
Hi @Todd_D_Anderson, sorry to hear you’re experiencing performance issues. As Dysfunk_DJ suggested, please provide specific details about your setup so we can try to replicate and troubleshoot your issue. If you can capture a short video of this, we prefer that you upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hello! It’s been more than 10 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
