I am setting up my Looper in DJay and I was wondering if it is possible to get a reverb effect on my loops on the Looper? I can’t see any option to route or turn on a reverb effect on this panel and the reverb section only affects the music I play from the main mixing section.
I would be grateful if someone may be able to shed some light on this, it may simply be there may be no option currently to add reverb on my loops which a suggestion would be my next step as it would work well in my setup to have this activated.
Thanks.
