I’m on djay ai v4.1.10, ipad pro 5th gen iPadOs 16.5
I have magic keyboard.
When I put automix, I want to casually listen to my tracks and I do not need to touch or open ipad, so I fold down the magic keyboard for easy carriage of the ipad.
Unfortunately djay pauses playback, until I open lid and unlock the ipad again, then it auto-resumes!
This is annoying because in my previous ipad pro 4th gen (2020) with the same magic keyboard, it would continue playing even when i do close the lid on it.
@Armigo I believe the iPad going to sleep when Magic Keyboard case is folded and closed. This means that the Auto-Lock/Unlock when the cover/keyboard is closed is not working.
Open Settings>Display & Brightness>Lock/Unlock : Ensure that this is set to OFF.
@Armigo I would try a force restart of the iPad to see if that helps as well (see below). Also, are you playing audio through the iPad speakers, a Bluetooth speaker, a wired external speaker or headphones?
@Slak_Jaw
I am playing via ipad speakers.
No, the ipad is NOT freezing or non-responsive in any way, but i tried that “force restart” procedure anyway. However the procedure doesn’t appear to work on this M1 ipad pro. Tried it both with ipad ON and ipad OFF states, no restart seen.
@Armigo thanks for the additional information. Unfortunately, I can’t think of any other suggestions for your specific issue. Here’s another article on how to do a forced restart of iPad Pro M1.
