Hi new user here so apologies if this has been asked, is it possible to connect my 2 cdj 2000 nxs and be able to use the streaming service beatport, i have seen a video by tte app makers where they connect a mixer and cdj 3000 to the app but on a mac, id like to be able to do the same, kind regards and thanks for any assistance.
According to the compatibility list, you can still only use Djay with CDJs on a Mac.
Hi @Ian_cousins, @Chris_R is correct. The Pioneer CDJs are not currently supported on Windows. Only on macOS. Please see our current hardware support list for Windows below.
Thanks guys i thought that was correct.
You’re welcome @Ian_cousins
