Can someone please help me. I’m using djay pro. I also have a premium package with Tidal. For some reason Tidal isn’t in my library. Can someone please help me fix it.
Hi Yardy,
Thanks for joining our Community.
So that we can better assist you, could you please provide the following information:
Which device do you have?
Which OS version is running on your device?
Which djay version are you using? (If you are using an iOS/ Android device, please open the djay settings and scroll down to determine the version number.)
Thanks in advance for the additional information! I look forward to hearing from you.
Cheers, G
I’m using a MacBook pro
Version 10.11.6
Djay pro Version 1.4.5
Hi @Yardy,
Thanks for the info.
Please note that TIDAL (and other new streaming services) are not supported on djay PRO 1.
You can get djay PRO AI on the App Store for FREE here.
Cheers, G
Thank you very much for the reply. Djay pro AI isn’t free. If it was just a one time fee. It wouldn’t be so bad but it’s per year. Crazy.
Djay pro ai isn’t free.
