While using my Wego 3, Djay Pro starts artifacting when choosing a new song. Djay 2 does not do this. I am wondering if my iPad 4 is not powerful enough to handle all the functions of Djay Pro, and if there is a way to lessen the burden of the software for my iPad Gen4? I am on iOS 8.3.
Hi Angel Boy,
we are sorry that you have to deal with graphical artifacts, can you try to capture those in a screenshot and send us the picture?
That would be very helpful, also which macOS version are you using.
Hi Angel Boy,
thank you for your the follow up and sorry for the misunderstanding of the operating systems.
Normally the internet connection shouldn’t be the problem.
Regarding your iPad, are you able and willing to update a newer iOS?
Hey there,
I totally understand, even though updates are normally helping to keep most apps running. Can you please send me an exemplary video of the caught audio artefacts via support@algoriddim.com?
I am on mountain lion, but will probably upgrade to mavericks.
They are Audio artifacts, sort of like latency. Not visual artifacts.
It is literally when I am choosing a new song from Spotify. Wondering if it has something to do with the online connection?
I would rather not, as then I will have to refuse updates from apple on a regular basis. It is not an easy decision for me. You really think that will fix it?
Ok, I sent it.
