Hi, does anyone know if Djay Pro can be used with Rekordbox interface 2 ??? I know it work with Reloop Flux interface
As you’ve tagged the post with iOS, I assume you want to use the interface with either an iPad or iPhone.
Based on the product page listing drivers as being required for both Mac and Windows, I would guess that it’s not class compliant, so will not work on iOS.
Thanks…probably i try the Reloop Flux
