When I start Djay pro on my computer It loads and suddenly crashes. I’ve already used the windows store troubleshooter, reinstalled the app and restarted my computer and none of these options work.
I also have the app installed on another computer and that computer has no problem.
Thanks for helping, but It’s already solved for me (yeah, I know I should’ve said that in a comment). After receiving a solution from costumer support, I had to delete everything with .com.algoriddim.com in credentials manager, but my pc gave me an error message when I opened it, so I searched and found this solution: https://youtu.be/z1JOjBVVQec
Check if your c:\users\Default folder is hidden. If so, unhide it.
And if you still have issues or if the folder wasn’t hidden, try this (it seems to be an issue with the grafics card that also has effects on Cortana, but can be fixed): The following link is a remedy for Cortana not working correctly and it also helped with the issue at hand here, justs jump to “Method 1”, do that, and “Method 2” if neccessary.
And if you still have issues or if the folder wasn’t hidden, try this (it seems to be an issue with the grafics card that also has effects on Cortana, but can be fixed): The following link is a remedy for Cortana not working correctly and it also helped with the issue at hand here, just jump to “Method 1”, do that, and “Method 2” if neccessary.
same problem here this is becoming a headache…Really
I’m now trying to figure out what to use with (reloop Mixon 4)
I use a Dell laptop w/windows 10 and it started out working just fine…and now it just cuts off while playing a song…please help
"Or send me the correct serato app. to use?
Mine crashes after about 5 seconds now (after initially working fine for 4 weeks). Have got an important gig in 10 days. I emailed Algoriddim 5 days ago but no response
Thanks for the help but no joy. The crash happens when I load some tracks in, after a few seconds. Weirdly, if I don’t touch the music it’s fine so presumably some conflict there, doesn’t seem to matter if Spotify or Media Player. Bemused!
