Djay pro+DDJ FLX4 hot cued tracks won’t start, Crossfader FX volume issue
I have DJay pro installed(latest version as of 6/29/2024)on my ipad air and I’m using it with DDJ FLX4. I’ve noticed that sometimes the tracks that I have hot cued don’t play when I press the play button, but when I move the jog wheel a little bit they do play, does anyone have a similar problem? I was wondering if there is a workaround.
Also, when I use Vocal Sustain in Crossfader FX, the volume of certain tracks gets really loud during transitions and I was wondering if there is a workaround for that too?
Thanks in advance.
Hi @kangsta, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Oh, sorry about that. Here are the details.
Device Model : iPad Air 5th Gen
Version of operating system : iPadOS 17.5.1
Version of djay : 5.1.7
Hardware/controllers used : DDJ FLX4
Thanks for the info @kangsta. Can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
