Djay Pro: exit loop -> sync problem
Using an iPad Air2 and Mixtour.
  • two tracks looping
  • sync on
  • exit loop on one track
  • tracks begin to drift (even during former perfectly looped segment)
  • re-sync solves the problem
It is as if the algo loses riddim (sorry - could not resist) or resets / inits and gets confused after exiting one loop. It does catch up after a while (16 beats or so), but disable / enable sync works way faster and in the meantime it’s basically a wreck.
I have the sometimes the same problem.
