Although Djay Pro is natively supporting DDJ-SX2, I could see several possible bugs as follows.
Does anyone have the same issue or is this because of my PC problem? Or even it is the default behavior?
Glad to see the solution if someone could solve the problem already…
Volume LED seems not working properly. It basically rises up with bass drums, but not that sensitive for lead part even Deck gain is maximized.
When Cross fader across the center, cue(monitoring) automatically switches somehow. If I move it to left(Deck1+3 side), Deck 2 cue turns on. To the right(Deck2+4), Deck 1 and 3 pre-cue turns on.
Filter knob maximizing LPF side would not make the sound disappear completely. Maximizing HPF side could make sound disappear completely.
Perhaps there would be some more issues that I have not seen.
This software could be the perfect one for me once those concerns are gone…! Thanks!
I am sorry to hear about the bugs you are pointing out.
-Regarding the LED Meter, is this the case for all of your songs?
-The automatical switching of the Cue when moving the crossfader (Auto Switch) can be disabled in the Pre Cueing djay options
-Added your feedback about our filter to our user request list. Thank you for pointing that out.
->> Yes. Such as melodic part does not make LED rises up even Deck gain is maximized in any tracks.(I only tried several tracks from Spotify)
->> Thanks! I confirmed.
->> Thank you! Glad to hear that you would put your effort even on a bit old controller. If possible, may I know how long you would take for investigation?
