Djay Pro for iPad - all song in key of C after analysis
  • Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro m4
  • Version of operating system (e.g. macOS 14.4.1): iPadOS 18.1.1
  • Version of djay (e.g. 5.1.2): 5.2.7
After analyzing “Recently Added” song list from iTunes Library, all the songs display they of C. Re-analyzing the song does not correct the error. Apparently, there is no way to manually enter the correct key.
Hi @manueldelatorre, please try the following.
  1. Log out of Apple Music Streaming from within djay and any Apple Music Apps or browsers.
  2. Close djay and follow the procedure below to perform a Forced Restart of your iPad: Force restart iPad - Apple Support
  3. After rebooting, launch djay and log back into your Apple Music Streaming account.
I hope that helps!
Thanks. This seems to have fixed the issue for newly analyzed songs. However, re-analyzing the songs assigned the C key signature does not overwrite the wrong key. Is there any way to change the assigned key?
You’re welcome @manueldelatorre. Please try the following:
  1. Select the Check Mark near the top right of the Library, then
  2. Select the songs you want to re-analyze by checking the Circles to the left of each song, then
  3. Select the dropdown arrow next to Actions, and
  4. Finally select the Analyze Songs.
Thanks. Unfortunately, I had already tried that method multiple times with no results. I ended up uninstalling the app in order to re-analyze the songs. In the future, it would be extremely helpful being able to edit the key signature manually.
Odd that the re-analysis process above didn’t work for you. Glad to hear you got it sorted out though. Thanks for the update and suggestion.
I got it somewhat sorted out because the solution was far from ideal, and I only resorted to it because I had just started analyzing songs. Looking forward to being able to fix wrong key signatures manually!
