DJay Pro for iPad supports iCloud
I noticed that DJay Pro for iPad supports iCloud
If I were to upgrade my account to 1TB with Apple, how do I put my music up in the cloud so Djay can access it??
Cool! it works.
Apple iCloud is not as fast as Spotify but nice to have as a backup or for tracks that are not on spotify
Can you add “list view” so you can see the full file names?
one way to access your iCloud drive very easily is to go to https://www.icloud.com. There you can simply drag and drop your music files and access them afterwards via your djay pro application.
I hope this helps to explain things,
keep it up,
