DJay Pro for my Macbook Pro isn’t working. It shows: “Not Responding” right after opening, and keeps bouncing in the dock, but never opens. It’s been like this since update 1.1.1
I use it for weddings every weekend of my life…
Does it work with the latest updates? I realy need to know. Thanx in advance.
Yes thanx, working fine on the 5 year old macbook. Starting to like this apple stuff
Sorry to hear that, Michael…
Did that already happen on djay Pro 1.1?
Can you give some further information on your Macbook Pro?
It worked fine with Djay Pro 1.1
It’s Djay Pro 1.1.1 where I am having the problem. Original Djay works fine though.
As for specs:
MacBook Pro (13-inch, Mid 2010)
Processor: 2.4 GHz Intel Core 2 Duo
Memory: 8 GB 1067 MHz DDR3
Graphics: NVIDIA GeForce 320M 256 MB
OS: Mac OS X 10.10.3
Any update?
Exactly the same problem for me.
The demo of DJay works, demo of DJay Pro not, cloeses with error.
Bought DJay Pro won ́t install an won ́t open.
