djay Pro for Windows 10 jog wheel lag
djay Pro for Windows 10 is lagging on my laptop. Every time I use the jog wheel and do anything else (crossfade, effects, etc.) it lags for up to 15 seconds. I’m currently using the DDJ-WeGo 2 and this has been happening for months now. I installed the latest Creators Update for Windows 10 and my drivers are up to date on my controller, also I re-installed djay Pro and nothing seemed to work. I also tried Exclusive mode which doesn’t really help at all. I tried using the controller on Traktor 2 and it works just fine. What seems to be the problem?
