Problems with my Hercules 4-Mx Controller with Djay Pro. It seems the jog wheels instead of scratching, it’s more of fast forward digital blip. It also takes me a few hard presses before the play button works. I’m not sure if it’s the controller or the software. Anyone else have this problem?
Second hand controller? Your buttons might be the problem?
Hi Ryan,
thank you very much, could you please contact our support via support@algoriddim.com, this would be great in order to help you out as fast as possible.
Keep it up,
No, Brand new!
