Hi, have looked this up, can see a couple of chats about it but no solution yet - Djay Pro iOS app offers the option to organise playlists by BPM, but doesn’t actually show what those BPMs are for about 90% of the tracks. The original app did/does, making it simpler to build a set in the moment. The only way I can see is to load each track individually then look at the BPMs, but that’s no use in a live situation when you have to make quick decisions. Any ideas, solutions?
Just noting the Djay2 app has the Analyze Songs option, can’t see the equivalent for the ‘pro’ app.
Hi AllyBally,
Both issues you have mentioned work on my iPad…
I just click on the “Sort” tab and it gives me the various options including BPM
And as far as Analysing Tracks, I just click on the “Songs” tab and the drop down menu allows me to Analyse from there…
I have attached pics so you can see what I’m referring to.
Hope this helps…
You are an absolute superstar, sending you a virtual thank you beer.
Glad I could help,Youright though, DJAY 2 was simpler to use…,Quite a lot of hidden features in DJay Pro…
