Hey all!
My bad if this question has already been posted. If so, I’d really appreciate if you point me to the answer, as I couldn’t find it.
I have an iPad (13.5.1), which I’ve connected to my DDJ400 using a lightening adapter (plugging the DDJ to the iPad and the iPad to a power source, charged at 100% / factory cables).
I have Djay Pro AI installed on my iPad. I started with DJay and upgraded to Pro when prompted.
I’m not sure if it was the upgrade to DJ Pro or not, but now when I connect my DDJ400 to the iPad, the controller powers on for several seconds, then powers down leaving only the blue “Release FX” light and red “hot cue” lights glowing.
Djay does not seem to recognize that there is a midi controller connected, and after downloading the MIDI Scope midi detection software onto my iPad, it appears the iPad itself does not notice the midi controller.
However, DJay Pro and the iPad are fine, as Djay recognizes my media libraries.
So, am I missing something here? Why is the DDJ400 powering on for a second then sleeping; why is DJay not recognizing the controller, and why does it appear the iPad is also not recognizing the midi input?
Any and all help welcome. Thanks a lot!
