Hi, I’m writing to request the addition of customizable midi mapping within the Djay Pro app for IPad. When using my Reloop Beatpad 2 at home, plugged into my iMac running Djay Pro 2, I was able to customize the mapping of my controller. Specifically, I changed it so that holding shift and turning the low EQ knob would adjust the low/hi pass filter for the respective deck. A small change, but it really improves the experience!
I would like to be able to implement the same change when using my Beatpad 2 while connected to an iPad. If this is possible, could someone please tell me how to do it? Otherwise, Algoriddim, is this something you would consider implementing?
Love your software! Thanks!
