DJay Pro Mac - Mixtour some controls having no effect
Hey everybody,
I have been enjoying DJAY pro on iPad with the Reloop Mixtour controller for quite a while.
Now, that I have been djaying online a lot, I thought I would give the Universal Mac App a try.
Plugged it in yesterday through USB and started playing around. I am on an iMac 5k with OS X 11.1 installed. DJ Pro AI 3.0.9
I got the pre-cueing working but found an issue with some controls not working, i.e. having no effect.
Master, CUE-vol, CUE-mix.
I went to the Mixtour config menu to check if these controls were recognised correctly, and yes they are! So, when I turn Master, the correct entry in the config is highlighted. Same goes for CUE-vol and CUE-mix. I can even see them change in the pre-cuing config. Only they are having no impact on the sound at all and thus I cannot control master-volume nor cueing-volume which is quite loud on my ears.
Device-Config is the following:
deck 1: MIXTOUR ch1-2
deck 2: MIXTOUR ch1-2
pre-cueing: MIXTOUR ch 3-4
MIXTOUR CONFIG:
CC0 Mixer Master Level
CC1 Mixer Monitor Level
CC6 Mixer Monitor Cue/Mix
Thanks for your help
Johannes
Hey again.
Found a solution. In the Audio-Settings “internal” needs to be selected.
Had it on “external” thinking the MIXTOUR is an external device.
With the internal-setting all controls are working fine :slight_smile:
Cheers, Johannes
