Hi. I. Have an pioneer ddj-sr
Does it work with djay pro for mac,?
Does anyone now how to map my midi controller?!
It is unfortunately not natively supported. However, you can map many of the features to control the software fairly easily. Just go to MIDI in the top bar, and then Configure DDJ-SR. To configure each control, move each button on the controller (ex. the Low EQ knob for Deck 1), and then select the corresponding functionality in the software.
Thank you! Ryan
