djay pro don’t recognize xdj-rx mixer mode , mapping is good , but when you plug the USB cable its not connect with the master volume of the Xdj-rx controller
the XDJ - RX is natively supported by djay Pro for the Mac. Do you accept the audio device dialog window when you connect your RX to your Mac?
That way the controller is automatically used as Pre Cueing and Master Device.
Cheers,Lukas E.
