DJAY PRO NOT ACTUALLY COMPATIBLE WITH iOS 12
I suggest you make it way more obvious that there is a difference between Djay PRO and Djay PRO neural AI. It is not at all obvious that these are different products and therefore I’ve downloaded a subscription that my ipad can’t meet the requirements. Its also super lame i can’t get the older version because its unsupported. Super duper lame
Hi @jordanzo_the_great, can you please confirm if you had purchased the old version of djay prior to djay Pro AI? If so, there are options for redownloading this. If not, it is no longer possible to purchase the legacy app.
