When I try to load a song from Tidal, the program waits for 1 minute and then shows an error message: Could not load track
The operation couldn’t be completed. (kCFErrorDomainCFNetwork error -1001.)
I checked the streaming quality settings for Tidal (normal, high). The problem is independent on whether I connect a controller or not and with Serato Tidal songs do load.
I tried uninstalling Tidal and Djay Pro, removing all cache and setting and doing a fresh installation.
MacBook Pro with Macos 13.3.1 (a)
With this problem the program is of no use, I’m afraid.
Thanks for the update @Ariskito83. In that case, I recommend you reduce the Tidal streaming quality within the djay settings until you have a better WiFi signal.
On your Mac, please disconnect your ethernet cable, connect to your WiFi network, navigate to https://www.speedtest.net, record your internet speed, and share a screenshot here.
Please repeat the above speed test and screenshot, but with your ethernet cable connected.
Thanks for the additional details @Ariskito83. I cannot think of anything else to suggest so I’ll have to forward this to the engineering team to see if they can reproduce your issue on their end. I’ll report back here when I have news.
I made it work:
I turned off network web proxy and now Tidal songs load in djay.
It it interesting that the proxy caused problems only here and not in other places like the Tidal app or Serato.
