Will Djay pro work well on a macbook air, i5 dual core, 1,6 ghz.
I won’t use it for videomixing.
I wonder if its runs 4channel and loops and effects smooth?
Thank you. Bought a old macbook to give it a try. Works great.
Please note that djay Pro requires Mac OS X 10.9 or higher.
You can check out the performance by using the demo version. Get it here:
http://www.algoriddim.com/files/djay_Pro.zip
