I had to reinstall my Mac, which I use with Apple Music to organise playlists, smart playlists, and more. I needed to extract all my playlists from djay Pro and convert them to Apple Music. I couldn’t find a simple way to do this, so I built an app you can drag and drop files into. Click Convert to save the converted playlist, or click Import to add it directly into Apple Music. If your library has been moved around, it rescans your files and corrects the playlists to work properly.
I haven’t not fully tested the windows version
