Hi.
When I hook up my m-audio xponent with djay pro. Djay pro recognizes the MIDI controller as m-audio xponent.
After that it is unresponsive. None of the buttons on the midi controller fail to elicit a response from djay pro.
Also, the default package is torq for the xponent. Do I need to install that as well’? Since it adds the m audio sound drivers, or is that not important?
Regards,
Deb
