So the main music window appears to stretch and can’t be taken back. Once you use the search bar once you can no longer use it. When I restart Djay Pro I can use the search bar once and then it happens again.
Is this reproducible? If yes, what are the steps?
Update to the new version.
Not one person is having this problem besides you. Very strange.
Yes it is reproducible. It happens every time now. I made a screen cast of it so you can see it happening. Find it here.
https://drive.google.com/file/d/0Bz-g…
It appears that worked for me. Thank you very much.
Please try the following:
- Quit djay Pro
- Launch Terminal.app
- Run the command “defaults delete com.algoriddim.djay-pro-mac CMMSearchLastWidth0”
- Launch djay Pro (edited)
If you are not using the App Store version, Step 3. will be:
“defaults delete com.algoriddim.direct.djay-pro-mac CMMSearchLastWidth0”
See if it works!
This should be fixed with the new update of djay pro to version 1.1. You can update it for free at the Mac App-Store.
I hope you’ll enjoy it.
Did you try to do what Adrian said?
- Quit djay Pro
Which operating system is your MBP running on?
I have the same problem with the Spotify search after the 1.0.2. update. Any fix?
Thanks, Eero
Should. Still the same problem on my 13" MBP. And still the problem’s only visible on the Spotify search. Works for the first search and the the bar dissapears “to the right”.
Yes many times and when I do it it says:
Domain (com.algoriddim.djay-pro-mac) not found.
Defaults have not been changed.
I’ve bought it from the Appstore and I’m running Yosemite 10.10.3.
I’ve tried to troubleshoot if I’m usin the terminal.app right etc. but haven’t found anything…
Sorry I didn’t mention that. I did (it autoupdated via Appstore). Still not working…
If you have the problem with the Catalina update please contact us right away via support@algoriddim.com.
Cheers
Same here after Catalina update.
I’m having this same issue, in 2019, on my 2015 MacBook Pro that just updated to Catalina OS. It was working fine last week before the update.
