Hey,
I downloaded djay pro after refreshing my pc. It start and you can see that the Program is loading. After a few seconds I get back to my desktop and the programn is closed… when I try to use it on another pc it ll work fine. Any plans why it doesn’t work on my laptop?
Hi @peakina,
So I can investigate further into this issue for you, can you share whether you are using Windows or Apple?
Additionally, can you share what OS you are using on whichever device you are using?
I’m looking forward to hearing back from you and have a nice day!
