Djay Pro support for Pioneer DJ DDJ-FLX6-GT
Im considering buying the Pioneer DJ DDJ-FLX6-GT for Christmas but I’m unsure if it is supported in the Djay pro software. I’ve seen people saying the DDJ-FLX6 is supported but nothing about the GT. I’m also little confused as to what the difference between the two decks are. I mean they look the same, is one “better” than the other? Thanks!
Hi @John_Caselli, welcome to the community. I’m checking with the engineering team to see if -GT version will work with djay Pro on macOS.
In the meantime, here are some videos explaining the differences between the FLX6 and FLX6-GT:
@John_Caselli the -GT should be plug and play with djay on macOS.
Thank You so much. Was getting kinda getting confused between the two!
You’re welcome @John_Caselli, happy to help!
