Will the Djay Pro support the Pioneer XDJ-RX controller Any time soon? Because I don’t know if I should sell my controller or wait until there’s a support for it.
Hey there,
after quiet some time, we are very happy to announce that
djay Pro for Mac 1.4.4 comes with full plug & play support for Pioneer XDJ-RX, DDJ-RR, DDJ-RX, and DDJ-SZ2 DJ controllers!
You are good to go after updating djay Pro.
Thank you for your patience.
Hey there,
Will it be out for Windows 10 any time soon please Kukas do you know?
https://www.algoriddim.com/hardware This page says it is supported, but i cannot seem to make it work.
The mapping worked right now, but i cannot get the sound working. Or i have two decks with sound and no headphone, or one deck with headphones…
Hi, how do you connect the mixer of the xdj-rx to djay pro 2?
All the other functions work fine but the volumes and EQs just aren’t responding
Hope you can help,
I’m on mac still btw
Do you have an answer? Can you send me; info@dj-direct.nl
