I am dying to get the mapping from Djay, too.
They told me they do not have it around two months ago.
I am not a mapping guy and experienced with it.
I am just wondering if you have already worked on it your self and create a mapping for S8 ? If yes, it would be great to get it from you. I am not sure about your reaction but I can pay you for it.
Here is my quickly made mapping for Traktor Kontrol S8 (2 channel and later editable with djay Pro):
How to set up mapping? - please follow this step-by-step guide:
First of all after connecting the Traktor Control S8 with your Mac, please press both “SHIFT + Back” buttons in order to set the controller to “Midi Mode” and press setup button left side of display:
This is a xml file? This is not possible: Double-click the provided “Traktor Kontrol S8 djay Pro MidiMapping.djayMidiMapping” file and press "Install Mapping… How much I do it?
Hi DJ aSa! I tried downloading the midi mapping from your link but I believe the link is no longer available. Could you please repost a new link.
I would greatly appreciate it!
Thanks man!
