Can’t do djay pro 12 june update from app store. Give error “this item is no longer available”, can anyone from algoriddim explain me why?
Another question is, if i have djay and djay pro installed on ipad, why the apps don ́t share same library? Need to have same history in booth, cues, etc… important that songs from spotify don ́t have to charge again, since there is a stream log in memory for booth apps.
There is a away automatic to achive this, or only through iTunes sharing?
Hi Lukas,
Solved this update bug by uninstall djay pro and reload again from purchased itens at appstore. It’s working again.
Since i have Djay pro and Djay for iOS on iPad and iPhone and Djay Pro for Mac, that solution it’s a priority to implement. Hope that be live soon.
Thanks Lukas for your reply
Hi Marcio,
I am sorry to hear that, which djay Pro version do you have installed right now?
We are working on a shared djay for iOS (our latest app) library.
Cheers,Lukas E.
