Acer Nitro
AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx 2.10 GHz
GTX 1650
16 GRam
Windows 11, 64 bits
Inicio el programa Djay Pro y apenas muestra la interface se cierra automáticamente.
Me podrían ayudar respecto a este fallo.
Inicié la prueba gratuita para testear, si no hay solución deberé cancelar subscripción.
Gracias
I start the Djay Pro program and as soon as the interface appears it closes automatically.
Could you help me regarding this error.
I started the free trial to test, if there is no solution I will have to cancel the subscription.
Thank you
