- Device model 2020 MacBook Air:
- Version of operating system Sequoia 15.1:
- Version of djay 5.2.5:
- Hardware/controllers used DDJ-FLX4, Mixtour Pro:
Summary of the issue:
The djay Pro window is too wide for laptop screen when the “Larger Text” Display option is used in macOS. The left or right side of the djay Pro window ends up off-screen.
How to reproduce the issue:
- Select “Larger Text” mode in the macOS Display settings.
EXAMPLES:
Floating Window (right side cut-off)
Floating Window (left side cut-off)
Fullscreen Mode (left side cut-off)
Hi @Michael_Wisniewski, thanks for the details about your setup, the issue and the screenshots - this is very helpful! I have forwarded this to the engineering team to see if they can reproduce the issue and offer any suggestions. I’ll report back here when I have news. Thanks!
Hey @Michael_Wisniewski, can you please confirm the exact MacBook Air model and screen size you have?
Also, FYI our minimum supported window / screen size is currently 1100 x 500 px.
MacBook Air (Retina, 13-inch, 2020)
Full Specs here …
https://support.apple.com/en-us/111883
