Hi, I don’t know if it is a problem for you, but when using mixon 4 with djay Pro iPad, after loading the song the gain jump to 0, so if you have the gain of the controller in + 3, when you touch the controller gain it jumps from 0 to 3.
It could be better if the gain control could work like the pitch, when you touch the pitch from the controller there isn’t a jump, it needs to go until the position of the pitch in the software to start working.
I tested activating the option of automatic gain, but the problem is the same. It looks like djay Pro on iPad doesn’t work like the pitch and this kind of jumps are not good.
Do you try some workaround? Do you know if Algoriddim is working on some fix or feature allowing this? Thanks!
