Hi,Does anyone know if Djay Pro works with the Numark iDJ pro controller?
Are there any benefits as opposed to using Djay 2?
I try djay pro with my idj pro.
But i prefer djay 2…
With djay pro you can’t have the waveform and the sampler on same screen…
Hi guys,
thank you for your posts.
The iDJ Pro works perfect with djay pro.
Compared to djay 2, djay Pro for example comes with the all new Beatgrid editing and the function to manually set the BPM.
Thank you guys for your interest in djay pro and have fun mixing.
