Is it possible to make djay pro working with Traktor S4 ?
I cannot fix it…
You can use it via “MIDI learn”.
- put your S4 into “MIDI mode” by pressing the “SHIFT” and “BROWSE” buttons simultaneously
- in djay, open “Configure” from the “MIDI” menu to start mapping your controller
What if the midi menu does’t give that option?
