I have a midi controller that does not appear in the product list. This controller is a DENON DN HC-4500
I want to know if it is possible to use this MIDI Controller with the program DJAY PRO This is the reason to buy the product.
For Macbook Pro 13.3" early 2012 with OS X 10.11
thank you for your thread.
The HC 4500 is not natively supported by djay Pro but you can use the midi learning feature to map the controller yourself or ask the community if somebody made a mapping already.
If you need help with the mapping please contact us.
Cheers,Lukas E.
