I saw that Djay Pro could connect to Ableton Live? Does anyone know what this is used for?
I was wondering what the best options are for loading my samples on a MIDI device such as my Ableton Push 1 which I could load samples onto. The question about this is do I run Ableton without syncing and select the same output device as Djay Pro is assigned to or will that interfere digitally and would syncing be better?
Thanks.
