The djay Remote app doesn’t have iPhone 5 support. It would be awesome if you could update it with support for iPhone 5 and any UI changes made to djay for iPhone. Thanks1
Hi Noah,
thanks for your feedback. I changed your post to an “idea”.
The app works on an iPhone 5. The UI just hasn’t been updated for the larger screen. But generally speaking, yes it’s compatible.
hi, is it alreade iphone 5 compatible?
fix djay Remote.
fix Remote app need iOS 8 need to fast add new eq add new pad
