Hate having to drill down into the menus to find out what the current/last loop size is.
Showing the current loop size on the normal screen would make it so much easier!
I would love to see this implemented so I can see the loop size instantly and be able to use looping a lot more off the cuff and instantly, instead of having to drill down the menus to check the loop size first and sometimes missing the perfect moment!
