Any updates how should i connected the console roland dj 202 to my iPad software is not compatible
The DJ 202 is not Class Compliant and requires drivers (available on the support site) to be able to work with a Mac but you can’t install them on an iPad, therefore it will not work.
Even if you were to put the drivers on a Mac, there is no native mapping available and you would need to midi map it all manually.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
