Hi, I tried to install Djay 4 on my mac with Max OSX 10.6.8 without success. I first installed the trial version of Djay 4. Then I checked the Option ‘Buy’ on the trial version and was redirected on Mac App Store, where i only find the Djay Pro Version, that doesnt work on my OSX 10.6. How can i get a Version of Djay, that works on OSX 10.6? Thankx for helping.
It’s $50, not $300.
Either pay the price and get the upgrade of downgrade your OS.
Simple.
Hi guys,
thank you all for your feedback.
@El Ramun,
Have you tried djay 3 you can download the trial via https://www.algoriddim.com/files/djay_3.dmg and if you like the software you can purchase it via http://sites.fastspring.com/algoriddim/product/djay3.
@Kamilah Stephens,
Hi Kamilah, could you please contact us via support@algoriddim.com and tell us your OS X and the email address you used for the purchase. We will get you the right djay software. Sorry for any inconvenience caused.
@Silvio Barra,
Hi Silvio, could you tell us which OS X and which djay software you are using, thank you for your help.
I just purchased Djay 4 for $19.99 and it gave me pro. HELP! they stoled my money. thats the link i just used and it stole my money. That link says Djay 4 for $19.99 on sale YES ITS VERY CLEAR cause i used the same link: but it doesn’t work. it downloads for 10.9 and newer, which is pro. that link does not work.
i would like to hear some answer to the previous question.
i got the same problem. i downloaded Djay and it worked until the last OSx update.
Nobody warned me about the consequences of the update.
Now it does not work anymore. but i already bought it and i need it for working.
The new link is for Djay Pro and it costs almost 50 dollars.
