Djay (Windows) Can ́t connect to spotify!
hey,
i have the trial version of Djay for windows an tried to connect the programm with spotify. I entered my e-mail and password but everytime i hit loggin, nothing happend.
And yes i have a spotify premium account.
Thanks for help.
Timothée
Hi there, we are very sorry to hear about that, this issue has our highest priority.
We are gathering information about the issue and will provide a solution as fast as possible.
I want to apologise that you have to deal with the issue.
the issue is now fixed.
Sorry for the inconvenience.
Same here. Finally bought the full version yesterday but can’t connect to Spotify.
I’m having the same problem. I tried lots of things including running the app as an admin (which is quite hard to do with windows store apps) and disabling the firewall. Nothing worked so far.
The spotify interface works other than the login button. Pressing return doesn’t work either, both before and after clicking the green login button. I tried signing up for a new spotify account through the app and it worked as far as creating the new account but still can’t login into either account.
would appreciate any feedback,
thanks in advance
Connecting your Spotify to Facebook seems to be a quick fix, worked for me also.
I have the fuckin same problem!! please help me:(
Same problem here to
Is there any solution to this? I just bought djay pro and the login button for Spotify doesn’t do anything
Please feel free to contact me directly, I have already submitted a ticket.
Same Problem here. 3 Days ago it works (Demo Version) and now after buying the pro Version for Windows the Spotify login does not work.
Is it a Windows problem? Can I switch my licence to Mac OS?
just connected my Spotify to my Facebook and it worked that way
First, hate hate hate the Windows App Store. Once I get done with that mess I have to struggle without success to login to Spotify. I paid $49 for this mess. If Traktor or Serato ever build the ability to sync to other services you guys are sunk.
Really disappointed.
Yep same problem here in the uk, seems the new release of 2.0.8 does not work with Spotify? Seems to wok on my flatmate’s Mac ok though. Just bought this and not happy!
Do we have the option to downgrade to 2.0.7 and hope it works?
I have the same problem. I do not want to use facebook. I want to sign in with my name and password as I have before. I bought DJay Pro for Spotify integration.
