djay with OMNI portable turntable
Is there anyone else using OMNI turntable with djay ?
Unfortunately, it still does not work properly.
Even when I calibrate the DVS, it works like an automatic scribble.
Also, MIDI assignments for the faders do not work.
Let’s give feedback to Algoriddim to get OMNI to support this! I will too!
Hi @nicefinga, it works fine for me :grinning:
I will post a video…
Tony.
Seriously!!!
I’m super excited and waiting!
Hi @nicefinga,
As promised a short video of Djay + OMNI.
https://youtube.com/shorts/sUvDLVZxbg0?feature=share
It works fine… with crossfader setting: cut
Tony.
Yay! Super Thx!!!
It was because I had the mixer in external mode.
I put it in internal mode and it worked!
Thank you so much for the help👍
Hi @DJTonyBlanck,
Thanks for your post!
Additionally, thank you for providing your video! This is great to see that you were able to configure the OMNI Turntable with djay.
We encourage users as well to test this out and report back with their findings, but for the time being the Omni is not an official supported device for djay.
Just tried it it works so good. You can map each fader however you want and even mix on it so amazing
think I need a reload mixtour and another omni for the best portable setup there is.
I made a tuto and a demo last July over OMNI integration:
https://www.instagram.com/p/CggmObWoxtZ/?igshid=YmMyMTA2M2Y=
https://www.instagram.com/p/Cgc4GD-oYD8/?igshid=YmMyMTA2M2Y=
So much fun to use OMNI + DJAY PRO !!!
nice if only there was a way to use headphone split cue I can’t figure it out… might get a vci 400 to see use the extra channels on it. setting both faders to volume faders makes it a mixing beast with auto double but it needs headphone cue
Yeah!
Je ne suis pas le.seul alors :wink:
DVS functionality aside, would you say the Omni is a better turntable than the other portable options like the spin and pt01 or about the same?
Way better !
@nicefinga @djkom agree?
Of course!!!
I had the Spin, but the OMNI has a better fader cutoff and is a superior piece of equipment enough without having to use the mod!
Absolutely !
The most impressive thing is that OMNI is made by Headachesound a small compagny with limited ressources while big companies can’t even bring something close in term of features/quality (usb C soundcard, contactless faders, ultra pitch…etc)
Just got an Omni and have to say that it works great with algorididm. I also have a Mixtour and somehow I’m able to use the outputs from it as well as the headphone cueing and the DVS functionality of the Omni. I don’t even have any RCAs coming out from the omni, and it makes me wonder if I could add a second Omni for an awesome mini setup.
For those that want to try the one Omni & Mixtour setup here’s how I got it to work:
  1. Connect the mixtour to your iOS device and select “output to speaker”
  2. Connect Omni and configure DVS with “line out 1&2”
  3. Configure main audio with output “mixtour 1&2” and cueing “mixtour 3&4”
  4. Assign Omni faders as desired (neural mix faders are fun!)
Time will tell if this is works consistently and I will update here accordingly to keep all the Omni stuff in one thread.
Hi, I have a Mixtour as well, and I´m interested in buying an Omni, I use an ipad with djpro, the mixtour is connected to speakers via rca cables, Can you please tell me if the omni stills works for you and how you set it up, also what kind of disk you use for scratching.
I was trying to see all the videos posted here but they are gone.
Thanks a lot!
I
Hi
I will try with v5 but no reason that it doesn’t work anymore…
I use a serato 7 inch vinyl timecode.
Tony.
Hello Tony, Thanks again for your reply.
I was reading in another post that you commented about the rane 70, Im posting this here cause the other post was closed, Just a question, can the knobs of the rane 70 be mapped? what about if I want to assign the mic knob to a wet and dry effect, This is possible?
Also In the custom pages, the ones that are empty can you assign, lets say, in deck A an instant effect of deck b? I´m looking at this mixer and also the Elite, but in the way i’m used to dj this configurations (that may be strange) are very usefully to me.
BTW I received the OMNI, it works on djay pretty good, the only concern I have is sticker drifting, I can´t get it to work right. Also I was able to connect Phase Dj without a DVS mixer, just the Mixtour reloop that has no DVS, I think this is kind of a hack… lol But is working, also with the drift but working… :slight_smile:
