DJAY2 for Android "The file URL can not be found"
I purchased DJ2 for Android and some of my locally stored music cannot be found for some reacon. WHen i type the track name in DJAY it comes up but when i click on it to play it i see the following error
Where is the exact path where the file i am trying to play is located.
Having the same problem and noone has answered this yet… Fed up of looking on the Internet.
You solved it?
Bro, just solved it.
If the Folder has any special character, like “á” or something, it will give you out that error.
