Djay2 stops playing after five minutes with idjpro after the latest iOS update, please hurry and fix
Hey Jason,
thank you very much for contacting us!Please try to delete and reinstall djay2 on your device, if that does not solve your problem please contact pus again.
By the way which iPad and which iOS are you using?
Best regards,
Alex
I use the iPad 2 with the latest iOS update, don’t remember if it’s 9 or higher
